Hello, I installed/uninstalled the wacom driver and run calibration several times but I can't get pressure sensitivity to work with Photoshop CS6 or Sketchbook 2015. In Photoshop everything under the brush window (F5) is grayed out and in Sketchbook I set the stylus responsiveness to maximum but besides being able to click/select menus and tools I can't even draw a single line or a point in neither of the programs using the pen. Any Advice?
solved this by installing the feeldriver ver 720-9 instead of the latest 720-10, then i calibrated using the tips from xiaohang.07 -> link Good luck if you have the same issue and hope find better help then I did
