SP2 and power cover.
Discussion in 'Microsoft Surface Pro 2' started by Darren Donovan, May 17, 2014.
  1. Darren Donovan
    Darren Donovan Member
    Oct 25, 2013
    45
    0
    6
    I see Battery 1 and Battery 2. Which is the battery in the cover, and which is the battery in the SP2?
    When I tap on the battery icon, it shows 1220 hr 50 min remaining. Does the "1220" mean 12 hours + 20 minutes? And the total time remaining is 12 hours + 20 minutes + 50 minutes?
    Thanks,
  2. mtalinm
    mtalinm Active Member
    Feb 14, 2013
    602
    85
    28
    cover is battery 2.
  3. Darren Donovan
    Oct 25, 2013
    45
    0
    6
    So does Battery 2 (cover battery) always drain first before power is drawn from the SP2's battery (Battery 1)?
    Thanks,
  4. jnjroach
    Nov 9, 2012
    7,735
    1,833
    113
    Seattle, WA USA
    Surface Book
    The Power Cover keeps the Surface Battery at 100% until it is drained, at which point the Surface Battery kicks in, during charging the Surface Battery charges to 80% at which point the Power Cover charges to 80% then the Surface Battery charges to 100% and then the Power Cover will finish charging...
  5. Darren Donovan
    Oct 25, 2013
    45
    0
    6
    Thanks for that info, pretty elaborate sequence.
  6. toaf
    toaf Member
    Jul 9, 2014
    231
    22
    18
    infront of my surface you silly person
    SPro2
    not allways true. they have been doing wacked out things, ive seen power cover charge 100% and surface is at 23%.. i would say the only times i see the odd charging is when im gaming and its docked witht the power cover on. but non-docking station it does seem to allways fallow the above rules
power cover sp2
sp2 cover
sp2 power cover battery info
