SP3 Bluetooth Audio Issues
Discussion in 'Microsoft Surface Pro 3' started by guyp2k, Jun 28, 2014.
  1. guyp2k
    guyp2k New Member
    Mar 17, 2014
    3
    0
    I received my new Marantz 1605 with Bluetooth this week and was looking forward to streaming Bluetooth from my SP3 to the Marantz which has been a nightmare. I hate to say this and will probably get chastised by the masses here but the Marantz works flawlessly with iphone 5s and both Ipads, zero issues.
    I am able to pair the SP3 and the Marantz but that is short lived and the connection will drop and I have to go through the entire process again. I have a week before my return window expires and given several issues including the more recent Bluetooth issues it is looking like I will return which is unfortunate because the SP3 has so much potential.
    I thought I would ask if anyone has any suggestions before I pack it in.
    Update:
    I had the following Kinivo BT dongle that I installed on the SP3 and it works just fine and provides a nice BT GUI to configure your BT devices. The SP3 native AVASTAR BT chipset is sub-par and needs a driver upgrade....I just don't understand a company such as Microsoft would not have better QC/testing before releasing the SP3. Below is the BT dongle that I am using and works fine...
    http://www.kinivo.com/Kinivo-BTD-40...archPage=1&searchRank=salesrank&searchSize=12
    Thanks
  2. benjitek
    benjitek Active Member
    Jan 7, 2014
    622
    70
    28
    SPro2
    Hopefully it isn't the same Avastar 350N chipset in my SP2 -- my WiFi connectivity speed drops in half when I have both Bluetooth and WiFi on, if I turn Bluetooth off, WiFi speed doubles. Personally, I'd take the device back, take the speakers with you and make sure they connect fine with both the floor model and the replacement they give you.
  3. wertzius
    wertzius Member
    Jun 21, 2014
    87
    19
    8
    Try this:
    1. Right click on the start button, select &quot;Device Manager&quot;<br />
    2. Find Bluetooth-&gt;&quot;Marvell AVASTAR Bluetooth Radio Adapter&quot;<br />
    3. Right click and select properties.<br />
    4. Go to power management tab and uncheck &quot;Allow the computer to turn off this device to save power
  4. guyp2k
    guyp2k New Member
    Mar 17, 2014
    3
    0
    I tried that and did not address the issue. The SP3 is going back to BB Monday and I will wait and see if and when MS addresses all the issues, if so I will definitely purchase again. Thanks for the suggestion.
  5. Rugbyguy541
    Rugbyguy541 Member
    Jun 25, 2014
    61
    27
    18
    OryGun
    I am getting the same issue when trying to listen to audio through bluetooth. Anyone have any other fixes besides getting a thing to plug into the only USB port?
  6. yonghong
    yonghong Member
    Dec 12, 2013
    236
    15
    18
    SP3's BT sucks, apple are doing this job better, the only things I complaint.
bluetooth audio issues sp3
bluetooth audio with surface 3
kinivo driver for the surface
marantz bluetooth issues
marvell avastar bluetooth audio profiles
microsoft surface bluetooth audio
surface pro 2 bluetooth audio problems
surface pro 3 bluetooth audio dropout
surface pro 3 bluetooth audio problem
surface pro 3 bluetooth audio sounds bad
