Stylus cursor point
Discussion in 'Microsoft Surface Pro 3' started by Gadigo, Aug 31, 2014.
  1. Gadigo
    Gadigo New Member
    Aug 31, 2014
    6
    6
    3
    Hi Surfaceianics,
    i have a short question: is it possible to turn off this cursor point that appears on the screen when holding the stylus in close distance over the display or while writing ? Had a samy galaxy note 10.1 before with such a possibility. Found nothing in the settings for touch devices or elsewhere.
    By the way, i really like this sp3, every time facinating to have a full pc in such a little tablet.
    Thanks for answers.
    gadigo
  2. ctitanic
    ctitanic Well-Known Member
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    Welcome aboard.
    "Hovering" can't be disabled. That's a Tablet PC feature very useful when using Windows.
  3. Liam2349
    Liam2349 Active Member
    Aug 2, 2014
    884
    132
    43
    There's no way I know of to disable it, but hovering can be very useful.
  4. Steeli
    Steeli New Member
    Aug 20, 2014
    17
    3
    3
    But not all the time! When i am writing in OneNote it is absolut not useful for me. Why not an On/Off toggle? I hate this feature statements that i have to use it like it is.... this went me away from apple..
  5. Tsurugaya
    Tsurugaya Active Member
    Jan 23, 2014
    396
    28
    28
    I'd say the hover cursor is indispensable, it let's me know when I can put my palm on the screen. But I can see the point of an on/off switch for those who see it differently.
  6. Gadigo
    Gadigo New Member
    Aug 31, 2014
    6
    6
    3
    Thanks for all your answers.
    I know that hovering is most of the time useful, but like Steeli writes, this cursor is a pain at writing or sketching. Mostly because it lacks slightly behind at fast movements.
    Perhaps MS is capable of inventig an on/off switch.
  7. Liam2349
    Aug 2, 2014
    884
    132
    43
    Just want to let you know, you can place your palm on the screen before it detects the pen.
  8. Tsurugaya
    Jan 23, 2014
    396
    28
    28
    When I do that it leaves an ink mark.
  9. Liam2349
    Aug 2, 2014
    884
    132
    43
    Perhaps it's to do with how you position your hand. It probably helps that in OneNote, ink only works with the pen, at least by default and that's how I like it.
  10. malberttoo
    malberttoo Super Moderator Staff Member
    Feb 26, 2013
    2,255
    428
    83
    Alaska
    Microsoft is supposedly coming out with a Pen Utility in the next few months I believe, that will let you change the functions of the Pen buttons, etc. You could always hope that they'll address the floating irritant at the same time and give you the option to disable it...
  11. ShiroEd
    ShiroEd New Member
    Aug 27, 2014
    11
    0
    I happen to agree with it being a distraction, especially when drawing.
    I has the effect of 'feeling' slightly sluggish when drawing quickly. It would be great to be able to toggle its visibility.
  12. kozak79
    kozak79 Active Member
    Nov 15, 2013
    296
    61
    28
    It's not the hovering, but the visual cursor that's the problem. It lags behind. You can disable it in some applications, like Sketchbook Pro and Manga Studio. It makes drawing much better. I wish there was a system wide way to disable the cursor when using the pen.
    Steeli likes this.
changing the pointer when using pen as pointer surface 3
how to disable the stylus pointer
how to remote pointer in sylus surface pro
remove curser when useing touch pen
surface disable stylus cursor
surface pen disable cursor
surface pro turn off stylus pointer
turn off point cursor surface pen
turn off solidworks pen cursor
win10 ink pen hover cursor
