Surface 2 battery not charging, won't update firmware
Discussion in 'Microsoft Surface 2' started by deeteeaye, Sep 23, 2016.
  1. deeteeaye
    deeteeaye New Member
    Sep 23, 2016
    0
    S2
    I feel I'm stuck in a vicious cycle. My wife has an old Surface 2 that came up as 'not charging, battery not detected', so I wiped it and restarted it. Now it says I need to update the firmware, but each time I try to run the updates it Fails. In reading up on it, I see the battery needs to be plugged in, or at 40% for the updates to run. Well...(see problem #1), without the battery charging and not detecting it, I feel like I'm stuck. It's well past warranty. Does anyone know if I take it to a Microsoft store if they'll assist? Any suggestions are welcome. I've tried uninstalling the battery drivers; holding down vol.+ button & power button for 5 minutes; resetting the tablet to factory specs...no luck with any of these. PLEASE HELP!
code 8024004c update
microsoft surface 2 battery not detected
surface 2 dant install firmware battery not charging
trick surface to download updates when battery not charging
