Surface 2 supports wired ethernet in 8.1
Discussion in 'Microsoft Surface 2' started by lppierre, Oct 20, 2013.
  1. lppierre
    lppierre New Member
    Oct 4, 2013
    8
    0
    1 person likes this.
  2. kristalsoldier
    kristalsoldier Well-Known Member
    Feb 24, 2013
    2,323
    362
    83
  3. lppierre
    lppierre New Member
    Oct 4, 2013
    8
    0
    RTFM! lol
    It's in the user manual for Surface2 with a note specific for RT so I'm sure it's a goer. All of a sudden Plugable dock is looking good;-)
    Regards
    Lorne
  4. kristalsoldier
    Feb 24, 2013
    2,323
    362
    83
    This is precisely where MS's problem lies - their right hand does not know what the left hand is doing. If the info is in the manual, then why the hell is their website describing the accessory not updated. This is more of an issue because they are saying effectively that with 8.1 the Ethernet capability is backward compatible. Bloody idiots!
  5. lppierre
    lppierre New Member
    Oct 4, 2013
    8
    0
    Hi K,
    I only know what I read in the S2 manual see attached. I'm pleased they flicked the switch so to speak;-) The logistics for MS must be a nightmare I'm prepared to cut them some slack;-)
    Regards
    Lorne
    Connect Surface to a wired network
    You can connect Surface to a wired network using the Surface Ethernet adapter.
    Surface Ethernet Adapter Surface Ethernet Adapter
    Notes
    To use the Surface Ethernet Adapter with Surface RT you'll need to update to Windows RT 8.1 and check Windows Update.
    The Surface Ethernet adapter is sold separately.
  6. thejoker1993
    thejoker1993 Member
    Sep 18, 2013
    46
    2
    8
    It is probably not compatible because the the rt is not usb 3.0..
  7. Series7man
    Series7man New Member
    Dec 16, 2012
    50
    3
    0
    Florida
    Actually I just looked the "New" manual for the Surface RT (the cover says with Windows 8.1) and it too says it can connect via an ethernet cable and has the link to MS's website for the adapter. Hmmm.
surface 2 ethernet
surface 2 ethernet 8.1
surface 2 ethernet danger
surface 2 ethernet support
surface usb to ethernet adapter
surface2 イーサネット
surface2 ethernet
surface2 wired network
surface2 wired usb ethernet
usb to ethernet adapter for surface2 with 8.1
