Surface pro 2 touch cover is skipping letters, has anyone had this problem?
Discussion in 'Microsoft Surface General Discussion' started by jovopham, Mar 27, 2014.
  1. jovopham
    jovopham New Member
    Mar 1, 2013
    10
    0
    Bogota, Colombia
    Surface pro 2 touch cover is skipping letters, has anyone had this problem? Is there any fix?
  2. sharpuser
    sharpuser Super Moderator Staff Member
    Aug 20, 2013
    3,376
    1,109
    113
    Pacific Northwest & China
    Surface Book
    When you move the mouse pointer with the trackpad or a mouse, is there a delay? I am asking, because your SP2 may be busy doing an update, and you are experiencing temporary delays. If so, the problem will clear itself up.
  3. jovopham
    jovopham New Member
    Mar 1, 2013
    10
    0
    Bogota, Colombia
    Thans, sharp, I have restarted severa times incuding a hard restart,,,,,,the updates are a up to date as you can see, some etters are ust sipping as of this morning when I turned my surface pro two on it was fine yesterday
  4. jovopham
    jovopham New Member
    Mar 1, 2013
    10
    0
    Bogota, Colombia
    I have switched out my keyboard with my wife's keyboard and hers works fine on my surface....mine skips letters on her surface, so it must be that my keyboard is gone out. I tried cleaning it off and cleaning the little metal connectors and turned the keyboard upside down and wiped with a soft brush in case anything had found its way into the keyboard, compressed air, etc., all to no avail!
  5. CrippsCorner
    CrippsCorner Well-Known Member
    May 31, 2013
    2,156
    241
    63
    Essex, UK
    SPro
    Time for a swap over then, shouldn't be an issue :)
  6. jnjroach
    Nov 9, 2012
    7,585
    1,809
    113
    Seattle, WA USA
    SPro
    Are you using the Touch Cover Gen 1 or Gen 2? Gen 1 had far fewer sensors and missing key was common, if you are using Gen 2 make sure you have the latest Firmware installed and clean with a Microfiber cloth the spine where the cover connects to the Surface.
    If that doesn't help you may have a faulty Cover.
  7. jovopham
    jovopham New Member
    Mar 1, 2013
    10
    0
    Bogota, Colombia
    A few hours after creating this post my type 2 cover totally died...I have ordered a new one. Meantime, I bought a wireless cover which is nice for my desk and large screen which is hooked up to my Surface 2. I may use the new type 2 cover for travel only.
  8. TunaSurface
    TunaSurface Active Member
    Mar 23, 2014
    347
    35
    28
    Finland
    I really don't get why people use touch covers anyway, i CANNOT stand them.
    Why would people use them over the type covers is just beyond me.
  9. CrippsCorner
    May 31, 2013
    2,156
    241
    63
    Essex, UK
    SPro
    Ordered as in paid for? You would have been able to exchange your old one over as it'll still be in warranty...
  10. jnjroach
    Nov 9, 2012
    7,585
    1,809
    113
    Seattle, WA USA
    SPro
    I disagree....I much prefer the Touch Cover 2 over the Type Cover 2.
has anyone have problem with surface
surface keyboard skipping letters
surface pro 2 typing skipping
surface pro key skipping
surface pro type ii keyboard skipping letters characters
when i type on the surface pro 2 it skips lines
