Surface Pro 2 with type case deosn't turn on when opened
Discussion in 'Microsoft Surface Pro 2' started by rege0039, Dec 4, 2013.
  1. rege0039
    rege0039 Member
    Nov 26, 2013
    130
    5
    18
    HI,
    Swapped my Surface 2 for a Pro 2 128. Put the same TypeCover on it and it doesn't behave the same as the Surface 2.
    When I open it from the keyboard it never turns on which the 2 did, I always have to press the power button.
    Am I missing something to make this work ? Or does a Pro simply not do that ?
    Thanks
  2. Booch
    Booch New Member
    Oct 31, 2013
    22
    2
    3
    Congrats on your new device!
    No, you're not missing anything. Not sure about surface 2, but, pro 2 does not wake by opening the keyboard cover.
    Tapping any key when opened will wake your sp2. Enjoy your device :)
  3. rege0039
    rege0039 Member
    Nov 26, 2013
    130
    5
    18
    So it does !
    Thanks.
    I do really like it, a little heavier and bulkier than the Asus TF 201 I had but much, much more powerful.
  4. Dane
    Dane Member
    Nov 8, 2013
    41
    4
    8
    Toronto
    I mistakenly thought flipping the cover open would turn the device on too...alas, it does not, as advised above. :(
    You get used to other means of turning it on!
  5. demandarin
    demandarin Active Member
    Aug 10, 2013
    614
    115
    43
    Tf-201....that's the Transformer Prime tablet. I had one when it first released. No longer have it but I still have its keyboard dock. Boy did that tablet bring some fun times on xda developers forum for it..haha
  6. daniielrp
    daniielrp Active Member
    Oct 26, 2013
    693
    133
    43
    Preston, UK
    I think it's down to the power usage it would take - the RT can survive for days in it's low power "connected standby" mode, so can detect when you open the cover, however a full on Intel i5? No chance of that lasting at all in a similar mode, not even sure it's possible for a x86 processor :/
    But it's hardly a bad thing, I've easily gotten use to just tapping power or a keyboard button to wake it!
surface pro 2 case
surface pro 2 open cover
surface pro 2 turns off when type cover used
surface pro 2 turns on inside case
surface pro turn on when case is opened
surface turn on when type cover opens
surface type case turn on
wake when open keyboard surface pro 2
