Surface Pro battery life - lowering display resolution? disable cameras?
Max_1981
Administrator
Hey folks,
anyone know if lowering the Surface Pro's display resolution to 1600 x 900, disabling the cameras (which are of no use for me), disabling some services, increases battery life?
Would be nice if anyone could help me with the matter.
Thanks
Max
leeshor
I doubt that the camera would use any battery unless you're using it. As for services, that's a very broad area. Most services are needed to allow Windows to function properly. Programs are a different story. If you have anti virus doing regular scan or mail doing frequent syncing or receiving/checking those things can affect battery life.
M
Max_1981
Administrator
Thanks for your reply. What you think bout lowering the screen resolution though. It doesn't seem to look any worse to reduce to 1600x900. Would this help maybe?
