Surface pro doesn't start
Discussion in 'Microsoft Surface Pro 4' started by Wim B, Mar 28, 2019.
  1. Wim B
    Wim B New Member
    Mar 28, 2019
    0
    Hello
    I have here a Surface Pro 5 witch screen is broken
    i' ve replaced a new screen , but the surface won't start up
    it loads its battery though
    issue : when I demounted the old screen the surface was still running
    I couldn't turn it off because of the broken screen
    Can this have created the startup problem ?
    Any one has experience with this
    many thanks
    greets
    Wim
  2. sharpuser
    sharpuser Super Moderator Staff Member
    Aug 20, 2013
    3,892
    1,194
    113
    Eastern USA & China
    Surface Book
    It sounds like the repair has caused this problem.
    It is possible that your Surface Pro 5 is running, but only the screen is not working. This could be tested with an external monitor.
    Turbo4AWD likes this.
  3. Turbo4AWD
    Turbo4AWD Active Member
    Sep 1, 2015
    301
    35
    28
    Other
    I agree with sharpuser. I would suggest trying to connect to an external monitor to find out what is going on. Then you can take proper steps to resolving the issue.
