Surface Pro login problem
Discussion in 'Microsoft Surface Help' started by Peter Heisey, Nov 14, 2014.
  1. Peter Heisey
    Peter Heisey New Member
    Nov 14, 2014
    0
    I am having an issue with a Surface Pro 2 that is on our domain and I can't log in. I get an error message "The trust relationship between this workstation and the primary domain failed"
    *All local accounts are disabled* so I cannot login and remove and re-join the domain which seems to be the easiest fix.
    Tried booting to a Linux disk to re-activate the local administrator account but it won't boot.
    I have also tried resetting the computer account in AD with no luck.
    Any suggestions?
  2. jnjroach
    Nov 9, 2012
    7,578
    1,807
    113
    Seattle, WA USA
    SPro
    It sounds like a Time Sync issue.... if you boot into safe mode can you access the Admin Account?
log in problems on surface pro 4
microsoft surface 3 login problems
microsoft surface hello login problems
microsoft surface login problems
surface error login
surface pro 3 log in problems
surface pro 3 login problems
surface pro 4 login problem
surface pro login problem
