Surface Pro Reset
Discussion in 'New Member Introduction & Site Assistance' started by box o rocks, Jun 3, 2013.
  1. box o rocks
    box o rocks New Member
    Jun 3, 2013
    0
    0
    Hi all. Happy to be a new forum member here. I just bought a new Surface Pro and have an (hopefully) easy question...
    Eventually I will be interested in re-selling my Surface Pro, if for no other reason than to upgrade to a newer model. When I use the "thorough" reset option, can I be assured that any personal data I had on it is not recoverable?
    Thanx.
  2. souldier
    souldier Active Member
    Feb 5, 2013
    243
    27
    28
    Turn on your bit locker encryption so that everything on your SSD will be encrypted and therefore unrecoverable. It's one of the advantages built into windows 8 pro and surface pro. If you don't encrypt the entire drive, then people can use software to find files formerly installed unto the SSD. To open bit locker, just search for it while on your start screen.
    If you want even more security, there is software you can use to delete files and make it impossible to recover such as the "Eraser" software tool
  3. mitchellvii
    mitchellvii Well-Known Member
    Mar 30, 2013
    2,483
    559
    113
    Charlotte, NC
    If bit locker isn't enough you can turn on the hurt locker and your SP will explode if anyone else tries to use it.
    Sent from Boards for Windows on Windows 8
    1 person likes this.
  4. smalltowngirl13
    smalltowngirl13 Administrator Staff Member
    Jun 18, 2012
    614
    50
    28
    Kansas
    Welcome aboard!
  5. cali
    cali Member
    Jun 19, 2012
    542
    22
    18
    Welcome to the site. Hope you've decided how you want to protect your Surface info.
  6. machistmo
    machistmo Active Member
    Nov 17, 2012
    791
    53
    28
    Raleigh NC
    Other
    I would doubt that the thorough option provides anything like a DOD level Mersenne Twister erase function. I would then assume that you need to at least secure erase the drive before selling it. Here are some articles on the topic:
    SSD Data Wiping: Sanitize or Secure Erase SSDs? | Kingston Technology
    Ask Ars: How can I securely erase the data from my SSD drive? | Ars Technica
    How to securely erase an SSD drive | How To - CNET
    And then one on how you can actually recover data from some of the above mentioned processes:
    Recover Deleted Files in OS X
how to soft reset surface
how to soft reset surface pro 3
reset surface pro 3
surface pro 3 hard reset
surface pro 3 reset
surface pro 3 soft reset
surface pro reset
surface pro soft reset
