Syncing between devices
Discussion in 'Microsoft Surface Pro 2' started by rtibbitts, Oct 22, 2013.
  1. rtibbitts
    rtibbitts New Member
    Sep 7, 2012
    29
    2
    3
    I ordered my Surface 2 Pro last month on the first day. Since then have been using my laptop to install all of the modern UI apps that I think I want on the Surface. Am I correct in saying when I first login to the Surface that it will port over all applications installed on my laptop?
  2. oion
    oion Well-Known Member
    Feb 15, 2013
    1,362
    265
    83
    S2
    Sync settings between PCs - Microsoft Windows Help
    Sync is for settings, not getting the apps themselves. You can log into the store on your new device and... I forget the exact sequence, but you'll be able to see all the apps you've downloaded before and can install them all that way, I believe. You'll have to log into both with your Microsoft account.
  3. Name Taken
    Name Taken Active Member
    Aug 11, 2013
    183
    26
    28
    Any good apps you would recommend?
stop syncing apps on surface 2 and laptop
stop syncing surface pro
sync surface pro 2 with notebook
syncing devices to surface
