tethering surface rt on android phone
bobdecastro
Is there anybody there knows how to tether surface rt to samsung android phone, its asking me to enter a network security key, where should I get network security key? thanks.
daniielrp
The network key will be on your Android phone. Which phone do you have? The process is slightly different on Samsung/HTC etc.
kundas1
I do it all the time, you have to SETUP the hotspot on your phone first and assign a password to your liking, then afterwhich when you turn on the hotspot you connect with the RT and when it asks for the password you enter what you put as the password...easy
leeshor
Make certain you have a data tethering plan or an alternative way of using your existing plan before you go so far you get super data charges.
