Type keyboard issues and losing mouse pointer
Discussion in 'Microsoft Surface Pro' started by cellsaver, Mar 20, 2013.
  1. cellsaver
    cellsaver New Member
    Mar 19, 2013
    5
    0
    0
    Frequently my Type Cover keyboard stops working, I find myself detaching and attaching it frequently just to get it to work.
    I know you're not supposed to detach while it's sleeping and I'm not doing that, but a lot of times after I've had it flipped back in tablet mode, then I change it to "laptop mode" nothing happens.
    Also, I lose my mouse pointer frequently.
    Just curious if anyone else is seeing these issues.
    TC
  2. YKinase
    YKinase New Member
    Mar 5, 2013
    20
    3
    Boston, USA
    I have had a similar problem with the missing mouse pointer. It simply disappears - usually when I'm in Explorer - but then pops back in after 30 sec or so. Touch still works. I plan to uninstall/reinstall the drivers - just haven't had a chance yet. I'll let you know if that works when I do.
  3. ArtfulDodger
    ArtfulDodger New Member
    Mar 20, 2013
    4
    0
    0
    I had this issue and eventually pointer went away. I called MS and am returning cover to get a new one. Sorry I don't have a better answer.
  4. Ruffles
    Ruffles Active Member
    Feb 19, 2013
    382
    67
    28
    I had this and it ended up be a defective surface that had to be exchanged. My keyboard would work for about 2-3 min and then stop.
  5. dleuen
    dleuen Active Member
    Feb 15, 2013
    163
    27
    28
    Littleton Colorado, USA
    This is exactly what I see. That's what makes me think it is software, not hardware.
  6. callen525
    callen525 New Member
    Mar 17, 2013
    11
    3
    0
    I have the same problem. However, I noticed if I touch the screen anywhere with my finger, and then go back and use the trackpad on the type cover, then it seems to start working. I am pretty sure it is a software problem.
  7. lkailburn
    lkailburn New Member
    Mar 18, 2013
    38
    3
    0
    CO
    I have the issue where if i flip the keyboard back behind it disables just perfectly but when i flip it forward into "laptop" mode it does not re-enable the keyboard.
  8. jeffskent
    jeffskent Member
    Mar 21, 2013
    76
    14
    8
    I have the similar issue in that I sometimes lose the ability to have keyboard input on the type cover, but never with the Apple BT keyboard I use at home. I can also type Control key plus F1 key combination to activate Gadsen Print Screen utility at any time with the Apple Wireless keyboard. The same key combination does not work with the type cover, however. I'm thinking that only one keyboard can be the keyboard "of record" at a time, but I don't know. Any thoughts or similar experiences with this?
  9. null4end
    null4end Member
    Feb 14, 2013
    69
    6
    8
    My Type Keyboard stops working pretty frequently when I am using it on my lap either on a laptop tray or just on my legs. I don't think I have ever noticed doing this when I am using it on a table or desk.
  10. riggi
    riggi Member
    Mar 29, 2013
    147
    25
    18
    Sometimes I have to fold the type cover back past 180 degrees and then forward again. Maybe a few times.
    I think the sensor that detects if the type cover is folded back or not doesn't always toggle correctly when the type cover moves from one position to another.
  11. lwetzel
    lwetzel New Member
    Feb 25, 2013
    2
    0
    0
    Well i just had the problem and was sitting here reading the posts, thinking the whole time as to why nothing was helping. then I looked at my Surface Pro and noticed I had my external monitor plugged in but not turned on. I unplugged the monitor from the Surface and immediately had the cursor. Ain't that a kicker. Working fine now and even plugged it back in. Geesh wonder if MS will read this.
  12. drolem
    drolem Active Member
    Aug 9, 2013
    293
    36
    28
    98052
    You can detach in any time you want -- no harm will be done. As a matter of fact, a detach/re-attach cycle is an easy way to fix issues with the keyboard.
microsoft surface mouse pointer disappears
mouse cursor disappears surface pro
surface mouse disappears
surface pro 2 mouse disappears
surface pro 2 mouse pointer disappears
surface pro 3 mouse pointer disappears
surface pro cursor disappears
surface pro keyboard issues
surface pro mouse disappears
surface pro mouse pointer disappears
