**UPDATE: Battery Issue: Brought Into MS Store... Suggestions?
Status
Not open for further replies.
ChrisPanzer
Ok, so I brought my SP3 into the miami MS store today, showed my battery was at 40% max capacity at full charge (23K Mw)
He looked at it for about 3 seconds and was like, "Ok, well give you a new one."
Definitely cool of MS, for sure. Wasn't expecting that.
So, my question is, should I keep this new SP3 unopened, and sell it on CL or Amazon, and put the $ toward a new SP4 or SB, or just stay satisfied with the good ol' workhorse Sp3? #firstworldproblems!!
As a side note, I did have a chance to check out the SB and SP4... Sp4 is nearly identical with regards to look and feel of the SP3, difference is SP4 is a bit thinner.
SB, though, is incredible.. It's amazingly light, display is crisp and trackpad feels great!!! I loved it!!
ChrisPanzer
ChrisPanzer
Question is, though, they are going to want my current Sp3, so, what should I do to swipe all the data, or do I leave that up to them??
johnj2803
that is awesome! good for you!
try selling it and make the most out of it and get the sp4/sb with a student discount! problem solved!
Status
