USB Port awkward tightness.
Discussion in 'Microsoft Surface Pro' started by hawkhell, Mar 6, 2013.
  1. hawkhell
    hawkhell New Member
    Mar 6, 2013
    12
    0
    0
    Columbia, SC
    I fumbled with putting a flash drive in my Surface Pro for a few minutes trying not to break something before I got it in the first time. It is slightly looser now but still could attach a string the the usb and swing the surrface around without a fear of it coming out. Anyone else have this?
  2. Cowboy
    Cowboy New Member
    Feb 17, 2013
    62
    8
    0
    No. Mine is pretty snug but not that snug.
  3. cme4oil
    cme4oil New Member
    Jan 8, 2013
    11
    3
    Mine is tight too but certainly not tight enough to swing it from a string.
  4. souldier
    souldier Active Member
    Feb 5, 2013
    243
    27
    28
    Mine is very tight. I personally like it. It makes it feel more solid, but it is not so tight that it is too difficult to put things in.
  5. J515OP
    J515OP Super Moderator
    Jun 19, 2012
    2,177
    262
    0
    Northern CA
    RT
    Mine was very tight initially but after a couple of uses it has loosened to just tight. It feels fine now though some force is necessary to insert and remove.
  6. bryanhayn
    bryanhayn Member
    Mar 3, 2013
    53
    3
    8
    Honolulu, HI
    I like it tight ;)
  7. MrGoodtunes
    MrGoodtunes New Member
    Oct 25, 2012
    14
    0
    Me too. Still, I always keep a thin coat of Vaseline on male USB plug. Not only to make it smooth inserting, but to reduce contact surface oxidization.
  8. bosamar
    bosamar Well-Known Member
    Nov 10, 2012
    1,453
    78
    48
    RT
    No problem here. It will get easier. The more you use it, the better it gets.
  9. plasm0
    plasm0 New Member
    Feb 10, 2013
    34
    5
    0
    chicago
    good thing we are talking about computers here...
  10. Arizona Willie
    Arizona Willie Active Member
    Feb 24, 2013
    685
    51
    28
    Mesa, Arizona
    Yeah, mine is super tight too. Actually difficult to insert a flash drive. I have to brace my Pro with my right hand on the right side and push it in with my left hand and it takes considerable force.
    I expect it will loosen up over time.
    At least i hope it does.
loosen stiff usb
scary eyes
surface book usb port tight
surface microsoft usb port tight
surface usb port tight
surface usb tight
usb plug tightness
usb port tight
usb port tight on surface pro
usb port too small surface rt
