Using double-click on pen for screen shot - how to get JPG?
Discussion in 'Microsoft Surface Pro 3' started by DianeK, Jul 9, 2014.
  1. DianeK
    DianeK New Member
    Jul 9, 2014
    6
    0
    I am able to double click the back of my SP3 pen to get the screen shot option. It takes it right into One Note, which might be fine much of the time. But, is there a way to get this to simply save as a JPG without going into One Note? I like to snip a few sentences when I'm reading and upload to Facebook and Twitter, with a link to the book, for example. Or, I just might want to share in FB something else that I grab on screen. What are my options, with as few clicks as possible?
  2. ctitanic
    ctitanic Well-Known Member
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    Well, my workaround is once I have it in OneNote desktop version I lunch Snipping tool and create a new capture that I can save as JPG.
  3. DianeK
    DianeK New Member
    Jul 9, 2014
    6
    0
    Thanks. I had a feeling it would involve snip. I suppose I could use snip right out of the shoot. But, I'll need to learn how to set up a hot-key for it or something. I wish I could pin snip to the corner of any page I'm on so I can just launch and use it. Maybe there is a way.
  4. DianeK
    DianeK New Member
    Jul 9, 2014
    6
    0
    argh! I'm in One Note with what I want in JPG and there does not seem to be a way to launch Snipping Tool. One note takes up the whole screen and there is no way to bring up task bar, unless there is a hot key I'm unaware of.
  5. jedge
    jedge Member
    Jun 12, 2014
    91
    34
    18
    How To: Create A Keyboard Shortcut For Snipping Tool In Windows 7
    Or just take a screenshot then crop it later:
    Method 1: Press and hold the Windows button, and press down on the lower volume button on the side of your Surface. Your screen will dim a little for a moment when you do this. (this saves to \Pictures\Screenshots)
    Method 2: On the keyboard, press Fn + Win + SpaceBar. (this also saves to \Pictures\Screenshots)
    Method 3: Swipe left to open Charms -> Share. Click the tiny down arrow and tap "Screenshot". (this will further prompt you where you want to share it to, i.e. mail, paint, facebook, etc..)
    cdf3 likes this.
double-click to save a screenshot to onenote
how to screen shot with surface 3 pen
how to take a screen shot with surface pen
one note pen double click wont take screenshot
screen shot double click
set up double account surface pro 3
surface double click screenshot
surface double tap pen screenshot
surface screenshot with pen
take screenshot surface pro 3 with pen
