Using FrontPage 2003 with Surface Pro 3
Discussion in 'Microsoft Surface Pro 3' started by GRN, Oct 3, 2014.
  1. GRN
    GRN New Member
    Oct 3, 2014
    2
    0
    Just wondering if anyone is using, or has used, FrontPage 2003 on the Surface Pro 3.
    I installed FP 2003 on the SP 3 and there are some display issues in the design view.
    I'm using it on a Windows 8 desktop and it works just fine.
    Thanks.
    GRN
  2. GreyFox7
    Jul 27, 2014
    6,674
    1,331
    113
    IDK, try a lower screen resolution...
    FP 2003 was discontinued 8 years ago, in 2006... run it on an XP VM :D
  3. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Welcome to the forum
    Someone is STILL using that.? ;);)
  4. GRN
    GRN New Member
    Oct 3, 2014
    2
    0
    Ha, yep they are :) Maybe not for long.
    Tried the lower resolution, didn't make a difference.
    Thanks for the reply.
    GRN
  5. malberttoo
    malberttoo Super Moderator Staff Member
    Feb 26, 2013
    2,255
    428
    83
    Alaska
    Haven't hear that name for years!! :D
    @GRN, welcome!
  6. PilotGav
    PilotGav New Member
    Sep 18, 2014
    15
    3
    FrontPage?? Seriously :)
    (I was its biggest fan back in the day. Dont get me wrong)
  7. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    So was I. Now on DreamWeaver. But I think I remember when my last customer using FP stopped but it was a LONG time ago.
  8. Liam2349
    Liam2349 Active Member
    Aug 2, 2014
    884
    132
    43
    Sounds like it may not support high-res displays. You could try running this software in compatibility mode for some version of XP, or worst case, you might have to lower your screen resolution.
    Seriously though, perhaps it's time for a software upgrade to match your new hardware?
  9. graye
    graye Member
    Nov 1, 2012
    77
    17
    8
    Yeah, I'm ignoring the original question...
    The replacement for FrontPage is called WebMatrix. It is a stark departure from FP, but it produces standard compliant pages. Yes, there will be a learning curve... (but what in life doesn't have a learning curve?)
    WebMatrix runs just fine on the SP3.
    Anyway, it's free... and so much better than FP.
    http://www.microsoft.com/web/webmatrix/
  10. jnjroach
    Nov 9, 2012
    7,578
    1,807
    113
    Seattle, WA USA
    SPro
    Getting it installed is a big achievement, right click on the Frontpage.exe or Shortcut and select properties, select the Compatibility Tab and check the box below:
    leeshor likes this.
  11. EHoskinson
    EHoskinson New Member
    Oct 3, 2014
    21
    5
    3
    I've been using FrontPage 2000 on my SP 1 and it works fine. Installed with no issues.
  12. macmee
    macmee Active Member
    Oct 15, 2013
    707
    69
    28
    Nobody uses emacs or sublime?!
frontpage 2003 on surface
frontpage surface
run webmatrix on surface pro
