Very Interesting Article on the Surface Pro storage
Discussion in 'Microsoft Surface Pro' started by BennyDBowser, Feb 7, 2013.
  1. BennyDBowser
    BennyDBowser New Member
    Dec 21, 2012
    25
    3
    0
    "The MacBook Air 128 gives you 77.3 percent of the advertised storage space for user data. The Surface Pro 128 gives you 75.2 percent of its advertised capacity for storing data. And with one minor tweak that doesn’t affect the system’s capabilities in any way, you can increase the amount of data storage space on the Surface Pro to 81.8% of the advertised capacity."
    Full Article here: Surface Pro versus MacBook Air: Who's being dishonest with storage space? | ZDNet
    There's a pretty awesome chart comparing the storage...
  2. J515OP
    J515OP Super Moderator
    Jun 19, 2012
    2,177
    262
    0
    Northern CA
    RT
    Finally picked up by a main stream source. About time. This is definitely a dirty little secret of the whole industry but for whatever reason Surface reviewers decided to pull this out as a major punch again MS's hardware.
  3. BennyDBowser
    Dec 21, 2012
    25
    3
    0
    I totally agree. It is good to see with your own eyes that the Surface Pro's storage is actually on par or better than its direct competition.
  4. flight
    flight New Member
    Jan 26, 2013
    14
    5
    0
    That was a good read. Unfortunately, the damage is done. No one reads the follow-up explanation; they only care about click-bait sensationalist headlines. The headline "Surface Available Disk Space Actually Quite Reasonable" doesn't get as many clicks as "BREAKING: Surface Comes With Zero Disk Space."
    Now, someone explain to the masses that the 11.6" MacBook Air gets the same or worse battery life.
  5. bosamar
    bosamar Well-Known Member
    Nov 10, 2012
    1,453
    78
    48
    RT
    Some of those ZDNet MS reports appear to be fair. If I 'was' to purchase a Pro it would certainly be the 128GB. I can see plenty of road warriors picking up the Pro in the coming months.
  6. ArnoldC
    ArnoldC New Member
    Nov 26, 2012
    1,537
    110
    0
    Makati, Philippines
    But, we know this already, right? :)
  7. BennyDBowser
    Dec 21, 2012
    25
    3
    0
    "We" may know...but like Flight said...the damage is done :(
  8. deavod
    deavod New Member
    Nov 11, 2012
    18
    2
    0
    Finally ZDNet looks into the 'problem' with the Surface Pro and low storage by comparing the Surface Pro 128 and the MacBook Air 128.
  9. Sin
    Sin New Member
    Nov 14, 2012
    470
    32
    0
    Connecticut, USA
    RT
    Nice to see a through comparison/explanation.
  10. BennyDBowser
    Dec 21, 2012
    25
    3
    0
