Volume cuts out entirely while set low
Discussion in 'Microsoft Surface Help' started by wormywyrm, Jun 22, 2013.
  1. wormywyrm
    wormywyrm New Member
    Jun 22, 2013
    11
    0
    When my surface RT volume is set around 12 I can hear it sometimes fine, but then when my movie/TV show/music gets quiet, the sound shuts off entirely. It is like someone pulls the plug on it. Then when it gets loud again, the sound turns on. What ends up happening is whenever characters are not talking the sound cuts out, then it goes back on halfway through the next word of dialog. It is super annoying. I can turn the volume up to 30-50 and it will not happen, but then the volume is too loud to fall asleep to. I will probably bring it to the microsoft store but I am not sure if I will be able to replicate the problem in a loud crowded mall, because the problem only occurs when the volume is low to begin with.
  2. hotphil
    hotphil Member
    Apr 7, 2013
    118
    8
    18
    There's quite a few reports of that issue. There was mention of it being fixed in a recent update, but for me the problem persisted.
  3. wormywyrm
    Jun 22, 2013
    11
    0
    Glad to know that I am not the only one. It has been frustrating... I often fall asleep to some radio/tv/music and this makes it impossible to do so with my surface.
    I am considering bringing it to the Microsoft store and seeing if they can reset it to factory settings. If it still doesn't work after that I might replace it with a new surface, I am concerned it will continue happening though.
    Have you tried refreshing to factory settings?
  4. hotphil
    hotphil Member
    Apr 7, 2013
    118
    8
    18
    I've put the 8.1 preview on and the issue is still there. Bit of a shame - I often do the fall asleep to music thing and not being able to have the volume low means I can't use a Surface for that.
  5. wormywyrm
    Jun 22, 2013
    11
    0
    Yes it is definitely still there with 8.1, possibly worse... Or maybe it was just the particular show I watched so far.
asterisk low volume audio cuts out
kindle volume cuts out
low volume microsoft surface
microsoft surface soind cuts in and out
microsoft surface sound cuts out
sound cut out on surface pro 2
surface pro 3 sound cut out
surface pro 3 volume cuts out
surface rt volume issue cut in out
surfacert sound problems
