Wacom stylus cursor gets stuck in ~1 inch box in upper left corner
Discussion in 'Microsoft Surface Help' started by natemiller82, Jun 6, 2013.
  1. natemiller82
    natemiller82 New Member
    Jun 4, 2013
    8
    0
    Hi, so I've found similar issues on other tablets, but nothing relating specifically to the Surface, and I figured I'd ask you guys before I contact support. I suspect it may be some sort of hardware quirk, or short of that, may require reinstalling everything
    Sometimes --- either after switching rotation, or sometimes when the device starts up the stylus is stuck in a one inch box in the upper left corner... if I move it, it will move within that box, but is pretty much useless outside of it. Restarting fixes the issue -- I can't reliably reproduce the issue either, but it seems to happen more frequently on startup when the keyboard is attached (but it will still happen when it is not attached).
    It's a minor annoyance that has been bothering me. I saw a thread elsewhere (I believe Microsoft KB, but I can't find it again) where the Microsoft agent thought it was a keyboard thing, but It happens to me (and the person in that thread) regardless of the keyboard (type cover) being attached. There wasn't a solution in there that worked for me. I figure I'd ask in here.... otherwise I'll refresh windows, contact support and maybe warranty it out.
    I do have the latest WACOM drivers, but I believe I had this problem before I installed them.
    Any help is much appreciated, thanks.
  2. Quicky
    Quicky New Member
    May 27, 2013
    18
    0
    Yeah, I have exactly the same issue, also running the new Wacom drivers. Not sure if it was happening before I installed them.
  3. natemiller82
    Jun 4, 2013
    8
    0
    I can now reliably reproduce it by shutting down with the keyboard attached. Even if I disconnect it before I start it back up, it will be stuck every time. It happens other times as well. ..I'm reinstalling everything tonight or over the weekend and we'll see. .I might do a warranty return.
  4. Quicky
    Quicky New Member
    May 27, 2013
    18
    0
    Did you have any luck with the refresh?
  5. natemiller82
    Jun 4, 2013
    8
    0
    So, I didn't have the error for a while after I did a complete restore of windows 8. I didn't initially install the new WACOM drivers until two days ago, but yesterday I had this happen again -- the first time since completely restoring it. I wonder if it's related to the new WACOM drivers... sucks because I use the pressure sensitivity in photoshop.
  6. SurfacePro
    SurfacePro New Member
    Oct 1, 2013
    2
    0
    I'm experiencing this issue, too. Installed Wacom drivers. Made a habit of powering down device. Experience issue when changing orientation. Contemplating uninstalling the drivers.
    The only temporary solution I know is restart.
    Any known updates or fixes?
  7. kram337
    kram337 New Member
    Feb 11, 2014
    0
    0
    I signed up just for this thread. I can't find any resolutions anywhere. In fact this is the only page I could find mentioning the issue. My stylus screws up every time I start the Surface. But perhaps the resolution is to not turn off the device with the keyboard plugged in. Although that's kinda BS.
    Is this strictly a Wacom issue? If so, do I really need Wacom? or can the stylus pressure be sensed without it? I'd hope not. The device comes with this pen, you'd think it's full functionality would be included.
surface pro pen corner
surface pro pen stuck in corner
surface pro pen stuck in top left corner
surface pro stylus stuck in corner
wacom cursor moves to upper left corner
wacom cursor upper left corner
wacom tablet arrow stuck in corner
wacom tablet cursor stuck in corner mac
wacom tablet pen stays in corner
wacom tsblet stuck in cormer
