wake up from screen timeout with tap on screen
Discussion in 'Microsoft Surface Pro 4' started by surfmaxx, Feb 15, 2016.
  1. surfmaxx
    surfmaxx New Member
    Feb 15, 2016
    5
    0
    Hi - can you wakeup your Device from Screen timeout (no standby or screensaver) - only with tap on blank Touchscreen?
    On my Lenovo this is possible - for better testing it would be cool if you can post your Output from following cmd admin command.
    powercfg -devicequery wake_from_any
    Thank you for your Support and help
    Greetings
    Maxx
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Welcome to the forum Maxx
    I think you meant to say tap rather than tab.
  3. surfmaxx
    surfmaxx New Member
    Feb 15, 2016
    5
    0
    Yes -sure sorry - wakeup with tap on Screen - the autocorrection..
    Thank you - nice to be here
  4. surfmaxx
    surfmaxx New Member
    Feb 15, 2016
    5
    0
    Hello - it would be very helpful if at least someone could run this command - on my m3 it's not possible to wake up, from blank lockscreen (only Display off), with fingertap. Maybe the i5 Models and higher are able to do that. I need this feature because. I use the surface as panelpc on the wall as"smartHome visu"
    Tx
    Maxx
  5. surfmaxx
    surfmaxx New Member
    Feb 15, 2016
    5
    0
    Hi again - i think i have to explain - the command i posted above is not a bad one, it only shows the installed devices, which are allowed to "Wake up" the System from "screen off". It would be very interesting for me, if the core-i5 or core-i7 models has more devices in the list. I'm looking especially for the entry "HID-conform Touchscreen" - This device allows you to tap on blank Screen for wakeup
    ->on my Lenovo ThinkPad Yoga i have it - on my m3 surface4 not.
    How about your i5 or i7 surface4?
    Here the Output of my m3
    Virtueller Microsoft-Adapter für direktes WiFi
    Marvell AVASTAR Bluetooth Radio Adapter
    Realtek High Definition Audio(SST)
    Intel(R) Smart Sound Technologie-OED
    Intel(R) Display-Audio (001)
    Markus
  6. Yillbs
    Yillbs Member
    Jan 20, 2016
    84
    11
    8
    Interesting theory, but the i5 / i7 models have no other devices listed. Being able to wake by touching the screen would be a nightmare for a device like this. you have to keep in mind that a yoga == laptop that flips over. It has a keyboard covering the screen, when it's closed. Our device, does not. Sure, maybe you purchased the accessory, but if you didn't, this would be nightmare. I understand that they should give you the option, but they were so hell bent on getting a thunderbolt port added, lots of things got left broken / un finished :)
  7. surfmaxx
    surfmaxx New Member
    Feb 15, 2016
    5
    0
    Ok - from this perspektive I'm with you - it was my hope that the surface 4 notice the difference between human touch and other touch - or give me the Option to Setup this.
    Thank you for testing - you tested it with a surface pro3?
tap surface pro 4 to wake
