What is the Turbo Boost Power Time Window default value
Discussion in 'Microsoft Surface Pro 3' started by codrut, May 12, 2015.
  1. codrut
    codrut New Member
    Apr 4, 2015
    15
    3
    I had noticed that on my SP3 i5/8GB/256 the value for Turbo Boost Power Time Window in Intel XTU is not 3 seconds but 0.00.....96... seconds (the lowest value). Is this normal? Why?
  2. Johnny365
    Johnny365 Member
    Apr 21, 2015
    297
    24
    18
    how long do you want it? Isn't it just to provide enough power for applications and then drops down immediately. It's not a constant, maintainable value.
  3. codrut
    codrut New Member
    Apr 4, 2015
    15
    3
    It's not that i want it different, but the Default profile from Intel XTU has it as a 3 seconds value. I am just curios why it's different on Surface.
  4. GreyFox7
    Jul 27, 2014
    6,720
    1,336
    113
    Yes, I believe it's normal. 9.1 mm thick and SDP is the reason why. Overall performance is better with a i5/i7 U series part running in SDP mode than it would be with the lower powered i5/i7 Y series part in a 9.1mm thick form factor.
intel i7 turbo boost power time default
intel turbobost turbo boost power time window
intel xtu turbo boost power time window
turbo boost power time window bedeutung
turbo boost power time windows
turbo boost power window sp3
turbo boost power window time
turbo boost time window
