what microSD card are people using?
MikeyG
Hi there,
I just had to return a Samsung 64 gig microSD card my SP3 would not work with. it might be the slot on my SP3 or the card. No idea but i want to try another card before i give up.
can people post what cards they have had success with please?
thanks!
nipponham
I don’t have a need to use a microSD, but the 64GB SanDisk Extreme microSDHC I have lying around works fine.
EldoInTheWeeds
I was cleaning out a closet and found a bunch of old cell phones I thought I already recycled. I pulled out their sims realized they were micro SD cards. You guessed it--they fit and work in the surface. One was 8gig. They even had some old pictures on them...
nato
I've been using a Strontium 64GB MicroSDHC UHS-1 Nitro 566x. Worked fine and had no problems at all with it. I've now moved the card into my phone as I wasn't using it as much as I thought I would.
