Why I really dislike using my Surface Pro 2
Discussion in 'Microsoft Surface Pro 2' started by djeemale, Aug 28, 2014.
  1. djeemale
    djeemale New Member
    Aug 27, 2014
    4
    0
    Firstly, the usual issues:
    • The magnetic power connector is fiddly
    • It is too heavy as a tablet
    • The metal case scratches easily
    • No built in mobile data option
    • Limited USB sockets
    • The pen is inaccurate in the corners
    • The pen does not have pressure sensitivity (out of the box, for the likes of Photoshop). Needs the Wacom driver
    • The pen has no secure home in the device (silly magnetic attachment on power socket is almost useless)
    • Expensive (especially in Australia where we pay premium prices (or a “tech tax”) on everything).
    Nevertheless, I'm not going to bag Windows 8.x (per se), as I really don't think it's as bad as many people suggest. I kind of get it and know it will evolve over time. Simple fact is, I can pretty much ignore the new UI, if I want, and run all my usual desktop apps on Windows 8.x. My another tablet is great for media consumption, but definitely not for productivity (like running Adobe CC, etc).
    However, I shall now explain why my Surface Pro 2 makes me curse it and loath it.
    My Surface (8Gb, 256Gb) is the most frustratingly unreliable computing device I have ever owned! And that is not a trivial statement; I have owned and used computers since 1983 (over 30 years), therefore, I know my way around them. And before anyone suggests I need to do a fresh re-install of Windows, I have already done that.
    So here is a list of the issues I am experiencing with My Surface, which make using it a horrible experience:
    1. It will not shut down or restart about 80% of the time. Yes, I have left it in “shutting down…” mode overnight, just in case it was doing something (there’s no SSD access light on the Surface, so I have no idea if it’s working or not), but that proved to be just a waste of power.
    2. It refuses to recognise the MS Wedge mouse far too often (despite trying to remove and reconnect the device). I mean, I could accept that the Surface may have issues with a third-party device, but another MS product?
    3. It does not update correctly. It just sits there saying it is “preparing to install” updates forever.
    Bottom line is, I am reluctant to use my Surface. It is neither a pleasant experience nor one I can rely on. And that really upsets me. I honestly wanted the Surface to be something I would want to use and be proud to show it off to all those who are desperately trying to justify their toy tablets.
    Maybe I need to blow it away and reinstall from new media!
  2. GreyFox7
    Jul 27, 2014
    6,793
    1,357
    113
    By comparison to some other device:
    • Doesn't have a magnetic power connector
    • Too light and gets blown off the deck
    • Metal case causes severe allergic reactions
    • Redundant data plans eating up the budget
    • Doesn't have a USB socket
    • Doesn't have a pen
    • Doesn't have pen support
    • Expensive and charges a hundred dollars for 10 dollar features.
    :D
    mwsvette likes this.
  3. callihan_44
    callihan_44 Member
    Oct 15, 2013
    98
    18
    8
    I would do a factory reset and then slowly load things back on and see if you run into something causing the issue. I think for ultimate computing you still need a power house desktop, for on the road imo there is nothing better for portability- computing horsepower than the surface pro line. I would never lug around another laptop again.
  4. Philtastic
    Philtastic Active Member
    Jan 4, 2014
    420
    79
    28
    Canada
    In terms of your list of problems, the only ones I agree with are that the case scratches easily and that it does weigh a lot for a tablet. The power connector is not that fiddly: just line up one end of it then let it get magnetically drawn in. Everything else you listed cannot be solved by looking to any other tablet device if you want full Windows on the go. In terms of your software problems, that's usually a sign that you've corrupted some essential files on your computer and that you should reformat as callihan suggests. I have Windows 8.1 running on a self-built desktop, a Lenovo laptop, and the Surface Pro 2 and all are running quite fine.
  5. javispedro
    javispedro Member
    Mar 16, 2014
    133
    4
    18
    Barcelona
    I agree with the hardware complains, but to be honest... I am yet to find anything better. If anyone finds it please tell. The SFPro3 is not an option because it is not wacom and because it is, well, larger...
    The final three problems are just the usual Windows problems.
  6. dutchiedave
    dutchiedave New Member
    Dec 28, 2013
    13
    3
    Almost all your complaints are things you knew before you bought the SP2.
    As for hardware failures I had problems with my SP2 (I also live in Australia) with the SP2 crashing on resume from sleep . I had mine replaced under warranty. They delivered a brand new SP2 within a couple of days - the new one has been perfect since.
  7. kundas1
    kundas1 Super Moderator Staff Member
    Dec 4, 2013
    1,663
    300
    83
    your reasons why the SP3 is not an option is just YOUR reasons, for others, 1 the bigger screen is better! yes when I first got my SP3 I thought the bigger size would be more cumbersome but in fact it's perfect..perfect for watching movies, perfect for reading and surfing, and perfect for just about everything else I can think of and it's lighter than the SP2... secondly just because it isn't a "WACOM" WHO CARES? the N'trig performs just as good and just as smoothly as the wacom... wacom isnt the BE ALL END ALL screen. just might wanna educate yourself first than miss out on something really good!
  8. kundas1
    Dec 4, 2013
    1,663
    300
    83
    I'm thinking perhaps your tablet might be defective and you might have to swap for a new one, OR perhaps trying to restore to factory again and then maybe that might fix it...
  9. grumpy
    grumpy Active Member
    Dec 12, 2013
    252
    45
    28
    Also, the SP3 is not an option due to the aggressive throttling resulting in poorer sustained performance than the SP2. 100g LIGHTER? WHO CARES? I gladly accept the 100g weight and 4mm thickness penalties for a superior cooling solution that allows the CPU to be used more effectively. And the SP3 screen glass is thinner resulting in distortion when pressing with the pen and it is more susceptible to cracking. Then there is the cruel joke that is the i7 version...
  10. javispedro
    javispedro Member
    Mar 16, 2014
    133
    4
    18
    Barcelona
    Yeah, I forgot the "for me" part, sorry. Obviously if you don't use the pen or use it sparingly I fully understand you'd prefer a thinner screen, less battery consumption versus a wacom. But I specially selected the SFPro2 because of wacom versus other candidates, so it's significant for me.
    Well, Microsoft completely redesigned it on the SFPro3. I don't know if the redesign is any better but it shows they weren't convinced with the original design either. For me it's better than a non-magnetic one so I won't complain.
    .... aren't you being overly aggressive here?
    I mean, it's heavy because it's powerful. But.. it's heavy. Some of use don't care, though.
  11. kundas1
    Dec 4, 2013
    1,663
    300
    83
    sorry but if you had read the forums a little better and educated yourself a little better, you wold have seen that the SP3 outperforms the SP2 in MOST cases and only through heavy GAMING does the SP2 fair a little better and throttles less... BUT THATS IT, the SP3 outperforms the SP2...
    100G is 100g for people like you who are complaining about it being heavy lol
  12. kundas1
    Dec 4, 2013
    1,663
    300
    83
    not being aggressive at all, but I find it funny that YOU find it heavy, really? according to you the SP3 is ONLY 100g lighter so it can't be THAT heavy, right? because the SP3 is light as heck!
    and again so what about the wacom it isn't the be all end all screen, TONS of people are quite happy with the ntrig.. so your point is moot... I find your obsession for the wacom screen is quite limiting to having a better experience with the SP3 and a better device...
    and as for the redesign, I think it wasn't because they weren't convinced but more of, listening to their customers who wanted it lighter and bigger and better screen... try not over analyze things.
microsoft pro 2 dislikes
surface pro 2 scratches easily
