Wifi Driver failure within an hour after 8.1 update on Surface Pro
Discussion in 'Windows 8 Forum' started by curney, Oct 18, 2013.
  1. curney
    curney Member
    Feb 7, 2013
    56
    4
    8
    Hi,
    about an hour after i updated to 8.1 my wifi broke. Im getting ""This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)" in the device manager for the Marvell Avastar 350N. I got the most current driver .cab file (versi14.69.24040.136) from another thread on here, put it on the desktop and tried loading it but I get the message that it is up to date and it doesnt help. Any thoughts?
    Thanks!!
    Curney
  2. mitchellvii
    mitchellvii Well-Known Member
    Mar 30, 2013
    2,483
    559
    113
    Charlotte, NC
    Uninstall the Marvell Adapter in Device Manager and select "delete driver software". Then once it is gone from your device list right click the Network Adapters heading and tell it to search for new hardware. The adapter will reappear then update it to the drivers you downloaded.
  3. mitchellvii
    Mar 30, 2013
    2,483
    559
    113
    Charlotte, NC
    I'm not having your issue but since upgrading to 8.1 final I can only get half the data speed I used to get. Have tried everything. Very frustrating.
  4. curney
    curney Member
    Feb 7, 2013
    56
    4
    8
    Thank you! that worked
    how do you check the speed?
    1 person likes this.
  5. mitchellvii
    Mar 30, 2013
    2,483
    559
    113
    Charlotte, NC
    Open Speedtest.net by Ookla - The Global Broadband Speed Test in any browser and run it. I found out what was killing my speed. Running a bluetooth mouse while on wifi will mess your speed up something awful.
code 31 surface pro 2
marvell avastar 350n driver
marvell avastar code 31
marvell avastar surface pro fail
marvell avastar wireless composite device
marvell avastar wireless composite device code 31
surface pro marvel driver load error
surface pro marvell avastar code 31
surface pro marvell wifi driver
windows 8.1 update from 8.0 wifi not working
