Wifi not connecting automatically after sleep or restart
Discussion in 'Microsoft Surface Pro' started by Quicky, May 27, 2013.
  1. Quicky
    Quicky New Member
    May 27, 2013
    18
    0
    Hi all,
    I've had a search around the forums and noticed number of issues relating to wireless connectivity issues, but not as specific as mine.
    The issue I'm having is that my SP rarely, if ever, automatically reconnects to my home wireless network after a reboot or wake from sleep, despite the option to Connect Automatically being ticked. I have to manually connect to my home network (wireless G, WPA2) each time. I never have to re-enter the password though. no other devices in my house on this network exhibit the same issue, including a Windows 8 laptop.
    Is this a known issue? Does anybody know of a resolution? Is it driver related?
    Cheers
  2. Nuspieds
    Nuspieds Active Member
    Feb 24, 2013
    783
    121
    43
    Los Angeles
    Surface Book
    No issues for me and I have a couple of WiFi networks I connect to automatically and after sleep and reboot it always reconnects.
  3. vinumsv
    vinumsv New Member
    Mar 20, 2013
    84
    10
    0
    India
    Do you have all the latest firmware updates installed ? also under Wifi Settings try disabling power saving option .
  4. Quicky
    Quicky New Member
    May 27, 2013
    18
    0
    Yes I have the latest firmware installed. After a bit more investigation, it seems that the wifi is automatically connecting, but not straight away. There is a delay of about a minute before it connects.
  5. Quicky
    Quicky New Member
    May 27, 2013
    18
    0
    Are there any driver updates for the Marvell Avastar 350N?
  6. psnative
    psnative Member
    Apr 9, 2013
    64
    8
    i had that problem when i first got my sp, & microchat said something about a sleeping driver...but it fixed itself...from an update is my guess. chat with microsoft & see if they have any answers.
  7. gabe406
    gabe406 Member
    Apr 25, 2013
    58
    4
    8
    After rebuilding my SP and updating all the drivers I noticed that I always had to reconfigure the Wi-Fi connection and every time I shut down or restarted I would have to restart the wireless configuration all over again. The one thing that finally work was deleting the wireless adapter and reinstalling it. After that it worked fine. might have updated the wrong driver. For what it is worth.
  8. cdf3
    cdf3 Active Member
    Apr 5, 2014
    188
    27
    28
    I've been having problems with my SP connecting to my wifi network after a reboot, wake, or sleep.
    It would take up to a minute to reconnect. I was in the process of wiping my SP clean, and start over from scratch.
    I didn't have it plugged in, so it wouldn't reset on battery power.
    I then came across your post suggesting to unintsall the wireless adapter. After doing so, it reinstalled itself, and reconnects have been much faster.
  9. richyo
    richyo New Member
    May 22, 2014
    0
    0
    No troubles with my home network, however my SP wont connect to my university network automatically :(
    This is when turning it on.
  10. CrippsCorner
    CrippsCorner Well-Known Member
    May 31, 2013
    2,156
    242
    63
    Essex, UK
    SPro
    Stop rubbing it in such a suggestive manor...
microsoft surface wifi reconnectibg
surface network not automatically
surface not connecting to wifi
surface pro 3 not connecting to wifi
surface pro 4 not connecting to wifi
surface pro no reboot option
surface pro not connecting to wifi
surface pro wifi not reconnecting
surface pro won't automatically reconnect to wifi
wifi not connecting automatically after reboot
