Solved wifi uses alot of CPU?
Discussion in 'Microsoft Surface Pro 4' started by starstreak, Dec 2, 2015.
  1. starstreak
    starstreak Member
    Oct 4, 2013
    246
    12
    18
    I noticed when my one cloud was syncing, and was dloading heavy to my device (802.11AC and running about 50Mbps) the fan would kick on and CPU use would be 80-100%. should it be like that?
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Probably. I'm seeing the same thing syncing IMAP on desktops. Syncing will do that if there is a lot to sync. Syncing is actually a multi step process of looking at everything on both sides to see if anything needs to come or go. There's more going on then most people realize.
  3. starstreak
    starstreak Member
    Oct 4, 2013
    246
    12
    18
    So once its synced, it shouldn't need to do that everytime, right? I don't have my charger and it went from 94%-75% and still syncing the IMAP apple account in outlook. :) I'll probably stay out of Outlook till I get home.
  4. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Normally it would only do a complete sync if you made a major change like moving a folder or a large number of files - or an account change. Once it has caught up it shouldn't be a big issue going forward.
    I just ran into this with a customer and his system will take hours to fully sync the first time, over 10GB.
  5. starstreak
    starstreak Member
    Oct 4, 2013
    246
    12
    18
    Yup that was it. Got home, and let it connect. Got hot, fan was on, but finished in about 5-10mins. wasn't keeping track. :)
  6. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Good deal!
this uses alot of wifi
ubs wifi uses cpu
