Surface Pro 9: 50% Limit set, but still charging to 100% *Resolved*
dssr
SPro7
Resolved.
Just in case other Pro 9 users come up against this.
The 50% Battery Limit function set in the UEFI does NOT work with Surface Dock 2, it only works with the included charger. A bit short-sighted considering if you're running 2x4K monitors or have other devices connected, then the Dock 2 will be powering the Pro 9 almost permanently. Thus not having the ability to limit battery charge other than the 80% limit (decided by Microsoft) is rather bizarre.
What was the resolution. I see this is marked as resolved, but it would be great to know what it was.
