Airport Extreme Workaround
Discussion in 'Microsoft Surface Pro 3' started by ctitanic, Sep 11, 2014.
  1. ctitanic
    ctitanic Well-Known Member
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    Some of the users that have Wifi issues they either own an Airport Extreme router or a router that's using the same SSID for the 2.4 Ghz and the 5 Ghz bands. Recently one of this users posted this picture to illustrate the speed difference between his MacBook and the Surface Pro 3.
    I asked him to change the SSID to a different one and post the same picture.
    A noticeable improvement in both devices.
    olimjj and leeshor like this.
  2. double07
    double07 Member
    Jun 21, 2014
    157
    17
    18
    I have older Apple extreme that can only do up to N at 300mbps at 5Ghz band. I just turned it on at tried it. Both my MBP 15 and SF3 able to connect to Apple extreme at maximum support link on 5GHz at 300mbps. I usually named my SSD as xxxx2 for 2.4ghz and xxxx5 for 5ghz. I don't name them exactly the same on any router.
  3. ctitanic
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    Using the same SSID?
  4. double07
    double07 Member
    Jun 21, 2014
    157
    17
    18
    why would one named both SSID the same? Does the router allow that? I never tried.
    ctitanic likes this.
  5. ctitanic
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    Ask Apple! Apparently that's what they are doing with the AC version of the Airport Extreme. I never has seen something like that.
  6. double07
    double07 Member
    Jun 21, 2014
    157
    17
    18
    I just tried the same name SSID on my Apple extreme. I would NOT let me. If you name both the same. It automatically disable the 5GHz band. If you forced the 5Ghz back on, it automatically appended "5Ghz" at the end of the name.
  7. raqball
    raqball Active Member
    Aug 17, 2014
    430
    156
    43
    California
    Surface Book
    On my N7000 I have the same name. One is lets say Home and the other is Home 5ghz.
  8. double07
    double07 Member
    Jun 21, 2014
    157
    17
    18
    "Home" and "Home 5ghz" are not the same.
  9. diamond.g
    diamond.g New Member
    Jun 20, 2014
    27
    2
    3
    VA
    The past three iterations of the Airport Extreme should allow for both the 2.4 and 5 GHz bands to be ran on the same SSID. That is the default configuration.
    What version software is on your routers? My AC is 7.7.3 and my non-ac extreme (first gen dual band) is 7.6.4.
  10. double07
    double07 Member
    Jun 21, 2014
    157
    17
    18
    7.6.4
  11. ctitanic
    Nov 3, 2012
    2,194
    577
    113
    Hollywood, FL
    Like I said, it's not in that way in the newest.
  12. diamond.g
    Jun 20, 2014
    27
    2
    3
    VA
    So under wireless options on the wireless tab I see a checkbox for the name, that indicates that you can in fact have the 5Ghz band as a separate SSID, but it isn't the default. Using a tool like WiFi Analyzer on my phone shows all the bands across my two devices using the same name.
- airport express rollbands & hof file
5th gen airport extreme shutting down on its own
airport extreme forum
airport extreme will not allow same ssid
connect surface to airport express
connecting a surface to a airport extreme
suface tablet with airport extreme
surface 3 airport 5 ghz
surface pro 4 airport extreme
surface pro hot to connect to 5ghz net airport extreme
