auto rotate and keyboard issues
Discussion in 'Microsoft Surface Help' started by sufiction, Dec 20, 2012.
  1. sufiction
    sufiction New Member
    Dec 16, 2012
    16
    0
    0
    CT
    the auto rotate keeps locking on me and when I pull up settings and try to click to unlock it, it is greyed out. Also the keyboard on screen sometimes will not pop up when clicking on a field to enter text. Any ideas on what I can do?
  2. ArnoldC
    ArnoldC New Member
    Nov 26, 2012
    1,537
    110
    0
    Makati, Philippines
    You can manually bring up the screen keyboard.
  3. sufiction
    Dec 16, 2012
    16
    0
    0
    CT
    I know that but I shouldn't have to swipe the screen and bring it up all the time yeh know. It should just pop up when the touch cover isn't on
  4. ArnoldC
    ArnoldC New Member
    Nov 26, 2012
    1,537
    110
    0
    Makati, Philippines
    It depends on the website. I've come across just one that does not bring up the on-screen keyboard automatically.
  5. bosamar
    bosamar Well-Known Member
    Nov 10, 2012
    1,453
    78
    48
    RT
    Future updates will make it more responsive. I have the same problem once in a while.
  6. J515OP
    J515OP Super Moderator
    Jun 19, 2012
    2,177
    262
    0
    Northern CA
    RT
    More than likely the website has a text filed coded in a non-standard way that doesn't trigger the keyboard. Hopefully the majority of the websites work for you, but like Arnold said it depends on the website.
  7. skido700
    skido700 New Member
    Feb 19, 2013
    7
    0
    I'm having the same issue. No, its not a website or responsiveness. It will not pull up the keyboard for anything, and the auto rotate button is grayed out.
  8. souldier
    souldier Active Member
    Feb 5, 2013
    243
    27
    28
    Auto rotate locks when the keyboard is active. The reason being is that if the keyboard is active with the kickstand out, then its obvious that you wouldn't want the screen to rotate while in this mode. When you fold the keyboard back, the keyboard will be disabled and auto rotate will no longer be locked.
microsoft surface auto rotate
microsoft surface screen wont rotate
screen rotation touch cover
surface auto rotate
surface auto rotate not working
surface pro auto rotate
surface pro screen wont rotate
surface pro wont rotate
surface wont rotate
