Hulu Driver Issue Easy Fix!
Sir Face
I just got off the phone with a Microsoft technician concerning the Hulu / Intel driver problem. This mornings "update" DIDN'T fix it, by the way. But anyway, here's the simple fix he did for me after a long consultation with his cohorts:
Open DEVICE MANAGER>Display adapters>driver tab>uninstall (DON'T CHECK "Delete software driver"box!!
Then bravely uninstall (it will flash black & back but don't panic. Then reinstall driver and it will revert back to the 3496 version, that's what you want (not the 3431). That should get your Hulu back up and running!
