Solved Keep SP3 on
Discussion in 'Microsoft Surface Pro 3' started by slacko, Nov 21, 2014.
  1. slacko
    slacko New Member
    Nov 21, 2014
    3
    0
    I would like to when I have the SP3 in the docking station using at a separate monitor be able to close the key board to take up less space and not have SP3 turn off or go into sleep mode. I assume there is a setting, but I haven't been able to figure it out.
    Thanks
  2. enthuz
    enthuz Member
    Apr 26, 2014
    116
    12
    18
    Have you tried this?
    VickiFL likes this.
  3. mtalinm
    mtalinm Active Member
    Feb 14, 2013
    602
    85
    28
    I just rip the keyboard off. then you can still use your hi-res SP screen along with your external monitor(s). I do this and have three screens to play with. plus, you can store your pen on the left side of the dock, which is magnetic.
  4. slacko
    slacko New Member
    Nov 21, 2014
    3
    0
    The Advanced Power Setting suggestion, worked like a charm.
    Many thanks
