Need an MPEG 2 streaming solution for Windows Surface RT
Discussion in 'Microsoft Surface General Discussion' started by rabilancia, Oct 28, 2013.
  1. rabilancia
    rabilancia Member
    May 27, 2013
    30
    4
    8
    Loveland, CO
    I own and regularly use a SiliconDust HD HomeRun Prime network tuner on my home network.
    Since the device is DLNA certified, all I need to do to watch TV on my Windows 8.1 Pro PC is to click on a link for the channel stream (MPEG 2) that I want watch. This works flawlessly on my 64 bit Windows 8.1 Pro desktop which opens the Windows 8.1 "tile" video app.
    When I try the same thing on my Surface RT with Windows RT 8.1, after the same "tile" video application opens, I get the following message:
    "Can't play. That item was encoded in a format that's not supported by your version of Windows."
    Has anyone figured out a way to add an MPEG 2 CODEC to Windows RT?
    Thanks in advance,
    Rich
hd home run surface rt
hdhomerun dlna surface rt
hdhomerun prime surface rt
hdhomerun prime windows rt
hdhomerun surface rt
hdhomerun windows rt
mpeg2 stream surface rt http
surface rt hd homerun
surface rt hshomerun
windows rt hdhomerun
