Solved processor speed won't go above 1.2GHz
JasperTheDog
Hi Guys,
I'm probably missing something obvious, but I noticed today when using Lightroom that the processor speed in task manager never went above 1.20 GHz. So I downloaded XTU and did a CPU stress test and again the processor never went above 1.20 GHz.
Is this normal? If not can anyone help. It's an i5 with 4gb ram.
Cheers
Colin
Fast-T
Are you running it on battery?
My SP3 won't go above 1.2GHz on battery, but run full speed while plugged in.
Chuck_IV
I'm guessing this also has to do with the Balanced Power profile it uses. I suspect if you try the High Performance Power profile(only available after turning Hyper V on), it will go above 1.2ghz on battery.
J
JasperTheDog
Thanks guys, yes it was on battery power, just never noticed it before and thanks for the tip regarding Hyper V.
cheers
