Solved SeaTools - short DST FAIL!!!!!! Help
Discussion in 'Microsoft Surface Pro 3' started by Riko, Jul 14, 2015.
  1. Riko
    Riko New Member
    Apr 7, 2015
    10
    0
    Ghent, Belgium
    hi guys...
    Little panic at the moment.
    I dropped my SP3 i7 512gig ssd from 30-40 cm (watching Tube in bed)
    No problems or rattling etc.
    Downloaded the Seagate Seatools for window software and ran a "short DST" diagnostic and it failed!
    Software manual said it takes 20 to 90 seconds but my test took a few minutes...
    http://www.seagate.com/staticfiles/support/downloads/seatools/docs/SeaTools for Windows.en-US.pdf
    it did pass all the other tests
    SMART test
    Short generic
    didnt do the long generic yet
    here is the software, can somebody else do the test and share their findings pls?
    http://www.seagate.com/be/nl/support/downloads/item/seatools-win-master/
    i am truely worried now my ssd will fail me one of these days...do i have to worry now?
  2. Riko
    Riko New Member
    Apr 7, 2015
    10
    0
    Ghent, Belgium
    edit: gonna install every known decent ssd diagnostic tool just in case :)
    for now SSDLife Pro (trail) says drive health is excellent and should last untill april 2024
    Samsung Magician software also showed good drive health status.
    Now INTELS Ssd Toolbox...does not work for oir samsung ssd
  3. sharpuser
    sharpuser Super Moderator Staff Member
    Aug 20, 2013
    3,406
    1,115
    113
    Pacific Northwest & China
    Surface Book
    Obvious question: Did it pass before the drop? Help file seems to be for much older Windows.
  4. Riko
    Riko New Member
    Apr 7, 2015
    10
    0
    Ghent, Belgium
    needless to say i wouldn't panic if i did this test before but i havent, so i cant know
    makes me wonder if i even should be worried when reading this: http://forums.atomicmpc.com.au/index.php/topic/26592-testing-a-ssd/
    he did a DST test from the begining and it too failed...
    another software I tried: http://crystalmark.info/download/index-e.html
    Gave me 100% and good health
    Id really like to see owners here do the same test so i can be reassured :)
  5. olimjj
    olimjj Active Member
    Mar 27, 2013
    550
    113
    43
    Where no man has gone before.
    @Riko
    The Sea Tools utility is a Seagate centric software meant primarily for their drives. Some of their algorithms might not be valid or compatible for all drives, intentional or otherwise. I would not worry. Your other software confirmed its health.
    Riko and GreyFox7 like this.
  6. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Just an fyi that I could throw a powered SSD across a room and still wouldn't be concerned about it, It's an SSD!!!!
  7. malberttoo
    malberttoo Super Moderator Staff Member
    Feb 26, 2013
    2,255
    428
    83
    Alaska
    Lol good point there. Not a single moving part in the things...
  8. Riko
    Riko New Member
    Apr 7, 2015
    10
    0
    Ghent, Belgium
    allright, seems plausible :)
    I had a normal HD drive from an HP laptop that fell from a little bit higher and with a bit more speed (heavier laptop compared to the SP3) and it functioned perfectly...for 2 days, than I was fucked :)
    In my mind I will be rest assure that the fall didn't do any damage to my SSD if after 2 days I can still use it. :p
    Just to be complete, here some screenshots of the various diagnostic software:
    Crystal Diskinfo
    [​IMG]
    Samsung Magician
    [​IMG]
    SSDLife Pro
    [​IMG]
  9. Ford Prefect
    Ford Prefect New Member
    Sep 22, 2014
    15
    7
    3
    any physical shock that would damage the SSD would first shatter the screen all sorts of ways.
    If the screen didn't crack don't even worry about it.
    Riko likes this.
  10. Riko
    Riko New Member
    Apr 7, 2015
    10
    0
    Ghent, Belgium
    thx
    my surface is still running as before ;)
  11. malberttoo
    Feb 26, 2013
    2,255
    428
    83
    Alaska
    Good to hear.
  12. stewartsoda
    stewartsoda New Member
    Aug 5, 2015
    2
    0
    DST stands for Device Self Test, which is a Seagate-only routine that probably uses special Vendor Unique SATA commands.
    Since you don't have a Seagate drive, it will fail.
long dst failed
saitools mail
sea tools short dst failed
seagate short dst failed
seatools short dst
seatools short dst fail
segate tool short drive self test on hitachi
short dst fail
short dst failed
short dst failed seatools
