surface pro 3 (i3/i7 versions) retail date pulled ahead!
Discussion in 'Microsoft Surface Pro 3' started by unruledboy, Jun 25, 2014.
  1. unruledboy
    unruledboy Active Member
    Jun 11, 2014
    320
    48
    28
    Sydney
    Surface Book
    surface pro 3 (i5 version) already hit retail stores on 20 June, and i3/i7 versions in US/Canada retail date moved from 31 August to 1 August.
    ok, now good news (sorta) for long long long waiting buyers from other 26 countries: retail date moved from 31 August to 28 August (well, it IS still earlier, right......)
  2. fonzman78
    fonzman78 Active Member
    Dec 28, 2012
    215
    142
    43
    Utah
    Surface Book
    Now this is interesting. With the i7 coming out Aug 1, do I return the i5 and go with i7? I will still be within the 45 day return period at Best Buy. Rats!!! Once again, do I really need an i7 or is it just envy. :)
  3. TechGod2014
    TechGod2014 Member
    Jun 25, 2014
    36
    6
    8
    Same problem here. Is the price difference really worth it? How much more performance will we get between the i5 and i7?
  4. kevinlevrone
    kevinlevrone Active Member
    Feb 3, 2014
    183
    33
    28
    Unless the i7 has some kind of upgraded cooling, I don't think the i7 can run faster than the i5 except for very small periods of time.
  5. gtext
    gtext Member
    Jun 22, 2014
    88
    9
    8
    Melbourne
    Look at it this way. A lot of the initial issues will have been fixed by the time we get it. Not always desirable to get a new product when it's first released.
  6. unruledboy
    Jun 11, 2014
    320
    48
    28
    Sydney
    Surface Book
    I already have i7+16g+4TB desktop, I don't need an i7 surface pro 3, if I need intensive tasks to run, I may just remote desktop to one of the virtual machines in my desktop.
  7. mtalinm
    mtalinm Active Member
    Feb 14, 2013
    602
    85
    28
    pretty sure that best buy is a 15 day return policy not 45. I checked specifically because I plan to return my i5 so I can upgrade.
    I figure that with a BB return due date of 7/3, I can go to the MSFT store on 7/2 and buy another i5 and use it for 30 days, then return it on 8/1 when I get the i7.
    for me every sliver of performance helps, but mostly I need the 512 disk (nearly out of space at 256!).
  8. Dim-Ize
    Dim-Ize Active Member
    Sep 24, 2013
    214
    38
    28
    Brentwood, TN
    I'm very curious about this as well. I am actually shocked that I didn't buy an i5 day one due to my personal nature of tech lust. Frankly, I just love my SP2 and didn't fall all over myself with the new one. I thought I'd wait till the fall or Christmas. But, after visiting this forum repeatedly, I suppose my delay is now a concern due to some of the valid performance issues expressed by this community related to heat and throttling. How in the world could the i7 out perform the i5 if once a heavy load is consistently underway unless radical cooling updates take place?
    I am not throwing stones here. I genuinely want to know. Is there a new CPU later in the year that is different or is the next release of i7 uniquely different?
    Embarrassingly confused.:confused:
  9. unruledboy
    Jun 11, 2014
    320
    48
    28
    Sydney
    Surface Book
    @Dim-Ize
    Intel already announced core M (5th gen core i, codenamed broadwell), Asus already has a prototype with 7mm thin tablet
    1 person likes this.
  10. JustABreathAway
    JustABreathAway New Member
    Jun 26, 2014
    10
    3
    Actually, I just spoke with a BB rep - as long as you're an Elite Plus member, your return window is 45 days for the SP3.
    Looks like Sunday will see me getting an i5 until my preordered i7 arrives on the 1st!
  11. Dim-Ize
    Sep 24, 2013
    214
    38
    28
    Brentwood, TN
    Thank you for clarity. In searching the web, I read this site: Intel Broadwell release date & specs
    Some key points listed:
    • Intel claims the Core M chips will take up half the space of its predecessors, offer up to a 40 per cent performance improvement and use 60 percent less heat. This also allows them to be fanless.
    • Broadwell will provide a 30% power reduction over the previous generation chip
    • Existing Windows 8 devices average between 6-to-8 hours on a single charge and they could finally crack the 10-hour barrier with Broadwell.
    This sounds like what I would want in the SP3, but I want to see how things unfold over the next few weeks with the improvements in firmware or drivers that may further improve mid-term results under heavy usage. From the way things are reading on this forum, while taxing the SP3 - it starts fast, gets hot, throttles back, and until it cools suffers in performance.
  12. bkydcmpr
    bkydcmpr Member
    Jun 24, 2014
    94
    11
    8
    that's the counterpart of the current Y series, microsoft probably won't use them in sp4, otherwise they would have put the Y series in sp3 already.
broadwell release date surface
build date on surface pro 3 i7
intel i7 difference for desktop and surface pro 3 versions
surface 3 i7 release date
surface pro 3 i3 heat
surface pro 3 i5 vs i7 virtual
surface pro 3 i7 heat problems
surface pro 3 i7 release date
surface pro 3 i7 running virtual machines
surface pro 3 retail
