Surface Pro 3 Micro SD card slot not working?
Discussion in 'Microsoft Surface Accessories' started by elpe, Jun 18, 2015.
  1. elpe
    elpe New Member
    Jun 18, 2015
    4
    0
    I have a Surface Pro 3 and just bought a 64GB Samsung Micro SD. The Surface doesn't seem to recognize the card! I've installed all the latest windows updates, tried restarting with Micro SD on but nothing seems to work! Any ideas on what I should do? Thanks!
  2. Spider
    Spider Super Moderator Staff Member
    Feb 3, 2015
    289
    74
    28
    Chicago, IL
    Have you checked the card by putting it into another device.
  3. elpe
    elpe New Member
    Jun 18, 2015
    4
    0
    Yes the card is working just fine in other PCs! Could it be a Windows 8 formatting problem?
  4. Spider
    Feb 3, 2015
    289
    74
    28
    Chicago, IL
    If the card is working on other Windows systems, it's probably not a formatting problem. Try "jiggling" the card, sometimes they don't make a solid contact when initially inserted.
    I'm also moving your thread to Microsoft Surface Accessories in case that doesn't work and you need more help. Good luck!
  5. elpe
    elpe New Member
    Jun 18, 2015
    4
    0
    Tried that and for a sec it appeared as if it was recognized but then disappeared again! Anything else I can do? Thanks!
  6. hughlle
    Jul 7, 2014
    3,072
    464
    83
    Try a different card if possible. There have been numerous reports of various cards not functioning properly with the sp3.
  7. kundas1
    kundas1 Super Moderator Staff Member
    Dec 4, 2013
    1,664
    300
    83
    make sure the card is seating properly in the SLOT... sometimes it doesn't seat properly so you have to push it in good
  8. elpe
    elpe New Member
    Jun 18, 2015
    4
    0
    Will try to borrow another microSD and try it out! thanks!
how to check drivers for micro sd card slot on surface
micro sd slot not working on surface pro 3
microsoft surface pro 3 micro sd slot not working 2016
microsoft surface sd card slot not working
sd card slot not working on surface
sd card slot not working surface pro 3
sd slot not working surface pro 3
surface pro 3 sd card slot stops working
where is micro sd card slot on surface pro 3
