Surface Pro charger not working
Discussion in 'Microsoft Surface Pro' started by Esteriel, Jun 6, 2013.
  1. Tracker
    Tracker New Member
    Aug 16, 2016
    2
    0
    SPro
    I am a bit late to the party, but am having a similar problem with my Surface Pro One. From time to time I would have to jiggle the plug to get the blue light to come on, but about two weeks go, my "low battery" icon popped up and I plugged the charger in. This time, no matter how I jiggled the connector, no blue light, so I left it on all day, but nothing. I thought the charger had failed, so I ordered another, which arrived today. Same result. I have cleaned the port and connector. At this point, the battery is so spent that the tablet turns itself off as soon as it fires up. Am I looking at needing a replacement battery?
  2. RickStrokes
    RickStrokes New Member
    Sep 2, 2016
    0
    SPro2
    I am currently having the same issue! My charger has been acting up recently and usually needed to play with it in order to charge, but after a couple of minutes of toying with it, it eventually would work. But it eventually crapped out on me. So i bought a new charger and it seemed to work fine, but catch this! I was at my girlfriends house last night and was using my Spro2 to play some music as we cooked dinner. My device battery eventually died and i didn't have the charger with me so i just let it be until i got home. But i noticed an orange glowing light coming from the right side of the SPro2. When i got home even my NEW CHARGER didn't work. tried cleaning it, hard resets, etc. Anyone have any ideas whats happening?
  3. Tracker
    Tracker New Member
    Aug 16, 2016
    2
    0
    SPro
    Hard to get answers to this. I am pretty sure my battery is OK and the problem does not look to be the charger, so it has to come down to the port and although I am reasonably handy, opening the tablet up and fooling around with the innards looks to be too intimidating. So, it looks like I have an expensive paperweight, and I had just bought a blu-tooth keyboards.
  4. hiker
    hiker New Member
    May 30, 2017
    0
    Thanks for the idea on shaving the connector. I used an xacto knife and took off a millimeter and it started working again (for now!). Maybe MS should include one with this product :)
  5. bobloblaw
    bobloblaw New Member
    Nov 3, 2017
    0
    I had a similar issue as Space Junk, but my charger had been working for about a year with no issues. Basically, it feels kind of loose when you push it in all the way (it can wiggle in any direction). It seems as if the contacts are somewhat shot, but with a little fiddling, I managed to get it working again. I just cannot wiggle it much in any direction.
  6. Bazza
    Bazza New Member
    Dec 12, 2017
    12
    3
    Solution is: buy PowerAdd rechargeable battery and surface pro connector - see Amazon
    The problem is clearly that the SP chagrers are trying to be too clever. The PowerAdd creates a simplet 12v charger for the battery.
    Only problem is that Amazon sourced SP connector is a bit flimsy but cheap enough, compared to Microsoft chargers, to buy several cables at once.
    PowerAdd can also charge many other bits fo kit simultaneously
    jaekqubp likes this.
  7. Asrade
    Asrade New Member
    Feb 9, 2018
    0
    Here is the issue with the charger. I found one of the terminals connecting to the socket head burnt and disconnected. See the picture below.
    Just open the charger's socket head (the one you plug into the wall socket) and repair it. It's a simple procedure. Please see the picture I posted here...
  8. Ezzy
    Ezzy New Member
    Apr 2, 2018
    0
    SPro
    My SPro charger randomly stopped working. The machine was fine, only the charger base was not working (not heating up).
    Anyway, booked an appointment at the Microsoft store for tech support. Got a coffee to pass the 15 minute wait. Went to appointment. Charger was dead. I got a good three years out of it. Tech personnel said, “That’s pretty good for a charger.” Bought new charger in store. Cost about $120 CAD. Machine back charging and working.
  9. Bazza
    Bazza New Member
    Dec 12, 2017
    12
    3
    I've often written on this problem with an SP3. New chargers work for a little while and then die although happily charging my phone through the USB.
    Unsure of the reason but I now use a Power Add battery pack and a 3rd party cable - works a treat.
  10. Bazza
    Bazza New Member
    Dec 12, 2017
    12
    3
  11. Bazza
    Bazza New Member
    Dec 12, 2017
    12
    3
    I've often written on this problem. Chargers have short life although the USB port usually remians working for phones. The last charger I bought laster about six weeks.
    I now use a PowerAdd battery pack and a 3rd party cable which has proven reliable.
  12. GreyFox7
    Jul 27, 2014
    6,876
    1,382
    113
    My 7 year old laptop chargers work fine, in fact I have an old Toshiba T1100 Plus that still works, I got it in 1986. :)
microsoft surface charger not working
surface pro 2 charger not working
surface pro 3 charger not working
surface pro charger not working
surface pro charger problem
surface pro charger problems
surface pro not charging
surface pro plugged in not charging
surface rt charger not working
