Surface pro screen interlaced?
Discussion in 'Microsoft Surface Help' started by Awetopsy, Nov 11, 2015.
  1. Awetopsy
    Awetopsy New Member
    Nov 11, 2015
    2
    0
    SPro
    HI there,
    First time poster... Just got my Surface pro. The problem is that the screen, when holding the tablet in landscape orientation, is showing every second vertical line of pixels as black. This creates an interlacing effect so that edges of windows and text look very strange.
    You can see a screenshot here:
    Zoom in a bit and look at the word "apps" on the left.
    This isnt a browser thing as it happens on every window, and desktop. IT seems to be there at lower resolutions as well. ITs just every second line of pixels, evenly spaced.
    Any ideas how to fix this? I tried downloading intel drivers, but the intel control panel doesnt show.
  2. leeshor
    leeshor Well-Known Member
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    Welcome to the forum
    Is your Surface Pro new??
  3. Awetopsy
    Awetopsy New Member
    Nov 11, 2015
    2
    0
    SPro
    no. Wish it were. Its an older surface pro 1
  4. leeshor
    Jun 19, 2012
    5,070
    877
    113
    Norcross, GA
    My thought is that a ribbon cable is loose or the digitizer is going bad. More than likely the digitizer.
