UK S3 owners - sound problems on iPlayer downloads?
timfg
As per the title - I get little pops and crackles on HD downloads from iPlayer - but not from other HD sources (Sky Go, Netflix etc). This seems almost certainly a codec issue - but I haven't seen anyone else mention it (yet). Am I alone?
hughlle
Super Moderator
How are you downloading them? If you tell me your routine, apps used etc, i can certainly try it myself for you (although granted it will be under windows 10)
T
timfg
Just using the BBC iPlayer app and the downloader that it prompts you to install. Have tried it on a couple of HD sources - this one for example:
http://www.bbc.co.uk/iplayer/episode/p02nb70t/peter-kays-car-share-episode-5
(not a fan, it was just short to test)
You need to listen for a minute or two before you start hearing it. After 5 mins or so, it becomes unbearable (I don't mean it gets worse, it just becomes impossible to listen to!)
