Weird battery life on the surface pro 2
Discussion in 'Microsoft Surface Pro 2' started by macmee, Oct 23, 2013.
  1. macmee
    macmee Active Member
    Oct 15, 2013
    734
    71
    28
    I have consistently had the backlight on 40% and just casual web surfing and email checking, and I have noticed that the predicted battery life on my unit (SP2 8gb model) has been quite inconsistent. I've had reports of 2 hours remaining on an 86% charge all the way up to 10 hours.
    I was wondering what I can expect out of this device. I also own a non haswell MacBook pro and I get about 5-7 hours out of that. Can I expect about the same from this?
  2. apoc_reg
    apoc_reg Member
    Mar 19, 2013
    96
    16
    8
    Should easily get that especially with that usage, a bit more id say.
    1 person likes this.
  3. deldalton
    deldalton New Member
    Oct 1, 2013
    99
    10
    0
    UK
    macmee. I've seen it mentioned frequently on these forums that the Windows 8.1 will do a lot of indexing when you first have the device. If that's true, it's likely that the inconsistent usage reporting you've seen may be because it's been working on indexing in the background, without you knowing it. Apparently, it'll all die down and you'll get a much more stable and longer battery life.
battery unknown remaining surface pro 2
odd battery wear surface pro 2
pro 2 battery life indicator
surface pro 2 battery indicator
surface pro 2 battery life forum hours
surface pro 2 battery life inconsistent
surface pro 2 battery meeter
surface pro 2 battery meter
surface pro 2 battery meter strange results
surface pro 2 inconsistent battery life
