Do USB 3.0 to DVI adapters work with Surface Pro to power monitor?
mitchellvii
Charlotte, NC
Seems the beveled edge on the display port connector (why MS why?) is causing people problems with standard display port to DVI connections. Thinking about USB 3.0 if it works.
The answer is yes. The other answer is just trim the collar of the adapter. I did this with a cheap micro to HDMI cable and it took about 30 seconds. It went from not working to working just that quick.
JP
