drag and drop text using surface pro 3 pen
Yao
I found I can not drag and drop text with the pen. For example, drag some text from ie to onenote. anyone knows how to set it ?Thanks.
Be more specific? How could you drag text between apps?
a fast way of copy and paste. I don't want to select copy in one app then select paste in another app. I want to drag text as easy as drag a file from a folder to another folder. In Ubuntu with the surface pro 3 pen , I can do that.
just like the image I uploaded. I want to drag the text.
I've never heard of this feature. Are you sure that it's possible with Windows?
But seriously, Ctrl + C and then Ctrl + V is the easiest thing ever.
Thank you so much. I think you are right. windows does not have this feature. I really hope they could add it.
You can drag & drop text within and between Office apps, but whether it moves text or copies text varies in different apps. Holding Ctrl while you drag forces a copy. I have a Notepad replacement (Metapad) which supports drag & drop text ant it works dragging into and out of Office apps.
And it works with the pen.
Thank you . I got it. Its the ie problem. I changed to chrome. and it allows me to do this.
Wow, very cool, didn't realize I could this till now! I'm always learning something new using the SP3. Beats the typical Ctrl-C & Ctrl-V. Mind you, it might only work on certain apps but very cool feature find.
