kelly4yllek
- Joined
- Dec 16, 2022
- Messages
- 2
- Points
- 1
- My Device
- SPro
I have a 65 watt pd mains charger that works well via USB C for my Surface Pro 8. I can even charge it okay with a 20W PD charger. (This is besides OEM Power cable which I normally leave at home.)
I see some external batteries that say they are also PD chargers. Anyone using one with their surface and what do you reccomend?
I bought my surface used and the the only real issue is I just get 2hr or so out of it. If I'm out and about it can be quite a hassle to find a wall socket and get plugged in. Ithink it may be worth it to find a decent external charger, realizing that what I'm after may be more expensive than a standard phone charger.
