More sound issues ....
Bill_Ohio
NE Ohio
Not sure if this is specifically a Surface issue, but I'm getting desperate.
I enter a lot of data into MS Excel and have used the "Speak Cell on Enter" feature in the past so I can hear what my fingers are typing. I am using Excel 2010.
This has worked on a variety of former laptops, but I can not get it to work on my Surface Pro 3. All updates are current, and sound works on YouTube and Itunes. It will also work when I open the Ease of Access controls.
I'd appreciate it if any of you with Excel could see if you can get yours to work, or give me some hints on what the problem might be.
Thanks!
Since this is an application issue it's getting moved to the x86 app area of the forum. Hope someone has an answer.
