Surface Pro X Dock
OSurfaceX
SurfaceProX
Hello everyone,
New member and Surface X Pro user here!
I am looking for a good desktop dock for my Surface, and came across the Kensington SD7000. Does anyone know if its compatible with the Surface X Pro, and if not can you recommend any alternatives?
Thank you!
Omar
I have the kensington sd7000 and it's only compatible with regular surface pros (4-7) size.. the pro x is a different size and moved the surface connect port further up..
You can use any usb c dock.. i've got one from komkaer that's like 9 in 1 and works fine for the pro x and pro 7 and surface go.
josher14
Thanks everyone, I guess i'll wait until they come out with a compatible version for the X pro
