UserForms on Surface Pro
TedN
Hi,
I've just got my Surface Pro and have copied an Excel program to it. The program makes use of UserForms. The problem I have is that I can't scroll the form using finger touch. It scrolls OK with a scrollbar but that's defeating the object of a tablet. The only way I can move the form with a finger is by touching the very top of the UserForm window.
Is there some setting I need to check in order to get the UserForm to respond to touch.
Thanks,
On my Surface I am using Excel 2013. The Excel program I copied was developed on Excel 2007.
