Overheating...Lost
Discussion in 'Microsoft Surface Pro 3' started by Rowan, Aug 25, 2014.
  1. bluegrass
    bluegrass Well-Known Member
    Nov 11, 2013
    1,308
    193
    63
    St. Louis, Mo
    Actually I'm pretty happy without disabling core functions of my klugy half baked Frankenstein gui Surface, that I don't have any reason to look for anything else.
  2. kristalsoldier
    kristalsoldier Well-Known Member
    Feb 24, 2013
    2,379
    371
    83
    Thanks very much. You are right. I don't have it since I have not downloaded it. One other question. You also advised to turn the Update Frequency from normal (default) to low. What is this Update Frequency all about? Thanks very much in advance.
  3. GreyFox7
    Jul 27, 2014
    6,894
    1,385
    113
    Go to the desktop and launch Task Manager. (touch and hold taskbar in the popup menu touch Task Manger)
    if you have the minimal Task Manager display touch - more details.
    Look at how often the information displayed on the various tabs is updated.
    On the View menu change Update speed to low. note the differences.
    Task Manager will use fewer resources and still provide the kind of information it should. it doesn't matter if task manager is not running... it only uses resources when you have it running.
    kristalsoldier likes this.
  4. kristalsoldier
    Feb 24, 2013
    2,379
    371
    83
    Right. Got it. Thanks.
  5. MilesTeg
    MilesTeg New Member
    Aug 3, 2014
    21
    4
    3
    Bah! My i7 SP3 just overheated on me for the first time while doing a factory refresh. I turned it back on and the refresh continued with no problems but I'm curious as to why refresh process caused an overheat given that I have gamed on this and have had it out doors in 90+ heat (web browsing and OneNote use) and had no heat troubles at all.
  6. dman27
    dman27 Active Member
    Jul 1, 2014
    121
    26
    28
    Seems to be sporadic. This happened to me only once on my SP3 I5 version during updates. Hasn't happened to me on the I7 version (knock on wood).
  7. bangsters
    bangsters Member
    Apr 15, 2013
    169
    15
    18
    Last night I played Infinite Crisis, and it got pretty hot at the back. However, not once did it shutdown or freeze due to overheating. And it was docked the whole time.
    Only gripe is I cannot play full screen on high quality with a 2560x1080 external display. FPS was just like 13 to 15. But not once did it overheat.
drawboard overheating
surface book heating up
surface book over heating
surface book overheat
surface book overheating
surface forums overheating book 2
surface over heating fan
surface pro 3 heating up solution
surface pro 3 overheating solution
surface pro 3 overheating solution win 10
